Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: Loose head bearings on my new 2017  (Read 1771 times)
Offline AndyAy
« on: May 28, 2017, 11:46:33 PM »
I'd got almost 300 miles on my new SX when there came a hard knocking from the front end during slow braking. I was a bit surprised that the dealer wanted me to ride it over to get it checked out. Anyway, I wobbled slowly to the dealer's, by which time time the front end was banging off every dimple in the road. The dealer and the mechanic said; not to worry, it's just your floating disks, they all do that. I stood my ground and said; if you take it out I think you'll find the headstock bearings loose. He did, and they were.  :192:
Forewarned is forearmed, people.
C100; C90; CB125S; RD200DX; CB125T; CB750FB; VFR750 (x2); NS400R (on loan); CBR1000FL; FIREBLADE 1996; TRANSALP, AFRICA TWIN; BLACKBIRD (x3), 1996, 2000, 2006; HAYABUSA 2006; FJR1000 2004; VARADERO (x3) 1999, 2001, 2008; VFR400R 1989; BMW R1200GS (x2); and now... Z1000SX 2017.
Online Broseley
  • 2014 Z100SX ABS Tourer
  • Bike: Z1000SX 2014
  • City / Town: Broseley, Salop
Re: Loose head bearings on my new 2017
« Reply #1 on: May 29, 2017, 07:56:51 AM »
OMG  :005:
2014 Z1000SX ABS TOURER, Michelin PR4's, Puig Light Tint Screen, Sargent Seat, Scottoiler, R&G Heated Grips, Bagster Tank Cover.
Offline DazF
« Reply #2 on: May 29, 2017, 03:20:27 PM »
Which dealer? All should be aware.
Offline AndyAy
« Reply #3 on: May 30, 2017, 06:19:45 PM »
*Originally Posted by DazF [+]
Well, I don't like to bad mouth dealers, and I've dealt with them for many years with no problems, I also think you'll probably get a similar response at most. However, if you were after a new Kawasaki in Newcastle, you'd probably come across them. The main thing is that I have committed to record the issue. If it happens to you, and the engineer says they never leave the factory with loose bearings, well... for all to see.
Offline DAC
  • Bike: 2017 Z1000SX
« Reply #4 on: June 23, 2017, 09:08:32 PM »
Andyay. Thanks for the heads up. Great post. I've just had my 17 put through the same treatment. And exactly the same responses from the dealer. Told them about your experience and they checked it and found the same. Cheers bud.  :828:
Offline AndyAy
« Reply #5 on: June 27, 2017, 06:45:21 PM »
Wow! It's not just me then.... :830:  Also I read your post about the stall after a throttle blip and mine's nearly done it and caught itself twice. Just a little stutter and I've noticed it and thought; wasssat?
« Last Edit: June 27, 2017, 06:54:41 PM by AndyAy »
Offline FriendlyEllis
  • Bike: Z1000SX ABS Tour
  • City / Town: Bedfordshire
« Reply #6 on: July 01, 2017, 08:15:41 AM »
On my 2015 I noticed a tiny knocking and took it in suspecting this (loose head bearing) when it was under warrantee.
They checked it and it was in fact the pads moving as they grip the disc as the pad springs are a bit weak.
It still happens, affects nothing and I'm happy..... But worth checking.
March 13 to March 15 - CB600F Hornet
March 15 to NOW - Z1000SX ABS Tourer
Offline madmic
  • Bike: Z1000SX 2016
« Reply #7 on: July 09, 2017, 02:16:33 PM »
Whats the symptoms?
My 2016 has a noticable 'click' feel when coming off braking - not really when you put on brakes.its almost due 7.5k service and under warranty so I'll have it checked but always good to know so can keep Mr Spanner on his toes!
« Reply #8 on: July 09, 2017, 07:10:06 PM »
*Originally Posted by madmic [+]
Whats the symptoms?
This is what I had Mic.  Just a little "click" as you come top a stop and the weight comes off the pads.
They checked it and said as above (just the pad springs letting the pads move).  They said it is more noticeable with after market pads.  I've not got after market ones though.  Standard are enough me thinks!
Offline madmic
« Reply #9 on: July 09, 2017, 08:06:02 PM »
Exactamondo what I'm getting!! Had it on an abba stand and gave the forks a good tugging in all directions, couldn't feel anything and steering is smooth.
