Author [ES] [CA] [PL] [PT] [IT] [DE] [FR] [NL] [DK] [NO] [GR] [TR] Topic: 2017 ventura rack install  (Read 1689 times)
Offline Mky
  • Bike: Ninja1000 2017
  • City / Town: Mackay
  • Country: Australia
« on: June 19, 2017, 12:18:43 PM »
Hi does anyone have install instruction for fitting a ventura rack to a 2017? Other wise any hints or tips?
Re: 2017 ventura rack install
« Reply #1 on: June 19, 2017, 01:53:23 PM »
Aren't they the same as the 2014 to 2016 models? If so plenty of info on here.
Offline Mky
« Reply #2 on: June 19, 2017, 09:14:38 PM »
I did look but found nothing, they are not the same to look at. The grab rails are different and can see where it would mount. I will get it tomfit but was just after details from someone who has done it
« Reply #3 on: June 19, 2017, 09:50:56 PM »
*Originally Posted by Mky [+]
Guess you didn't try very hard then ... I have extensively catalogued this  ...
https://www.z1000sx.co.uk/index.php/topic,4787.20.html
and
https://www.z1000sx.co.uk/index.php/topic,4787.0.html
or ...
Just put VENTURA into the search parameter.
If you want any further help ... my mobile is ... 07900198020
Offline Mky
« Reply #4 on: June 19, 2017, 10:06:25 PM »
Great thats perfect, I did seach but must have pressed a wrong button anyhow great info and thanks
« Reply #5 on: June 19, 2017, 10:18:09 PM »
errr .. Just realised your in Aus!!!  :oh_no: .. so pm me if you need any help ...
Offline StuL
  • Country: Straya
« Reply #6 on: June 20, 2017, 06:17:48 AM »
*Originally Posted by KD [+]
No call him at 3am ! :008:
Offline Mky
« Reply #7 on: June 20, 2017, 09:41:44 AM »
All done and dusted, was an easy job
Offline madasadad
  • Z1000SX 2017 WHF
  • Bike: Z1000SX 2017
  • Country: Norn Iron
« Reply #8 on: June 20, 2017, 10:02:50 AM »
Can you post a few photos of the install?
Offline Mky
« Reply #9 on: June 20, 2017, 10:43:12 AM »
Fit is normal on the pillion pegs
Now for the back remove the seat
Unscrew the bolt holding the back grab rail
Drill small pilot hole down to locate where the plastic needs to be removed
With a dremel with a sanding wheel remove the plastic from the grabrail  in just past the small pilot hole
The silver spacer goes into the are where the plastic is removed
Screw the 60mm m8 bolt down from the top through the grab rail
Slide on spacer then venture bracket washer and nut
Hope that helps
